sorry for delay, I could not get the log before than now https://tricorder.pi-hole.net/wsF6X6IR/
I don't know why the log is still empty, but i checked the issues..
2024-03-27 19:22:41: server.c.1513) server started (lighttpd/1.4.59)
2024-03-27 19:22:41: gw_backend.c.475) unlink /run/lighttpd/pihole-php-fastcgi.socket-0 after connect failed: Connection refused
2024-03-27 19:23:15: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: SQLite3Stmt::execute(): Unable to execute statement: attempt to write a readonly database in /var/www/html/admin/scripts/pi-hole/php/groups.php on line 947
but permissions seems to be ok when i get them from inside the container:
# ls -altr *.db
-rw-r--r-- 1 pihole pihole 98304 Mar 27 19:20 gravity_old.db
-rw-r--r-- 1 pihole pihole 98304 Mar 27 19:22 gravity.db
-rw-rw-r-- 1 pihole pihole 18751488 Mar 31 00:04 pihole-FTL.db
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
count last timestamp type message blob1 blob2 blob3 blob4 blob5
1 2024-03-30 22:43:49 DNSMASQ_WARN no address range available for DHCP request via docker0
-----tail of FTL.log------
[2024-03-28 19:22:59.045 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-28 19:27:24.751 120M] Resizing "FTL-dns-cache" from 20480 to (1536 * 16) == 24576 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-28 20:33:06.222 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-28 21:38:04.487 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-28 22:37:24.370 120M] Resizing "FTL-dns-cache" from 24576 to (1792 * 16) == 28672 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-29 00:44:23.287 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-29 01:49:12.451 120M] Resizing "FTL-dns-cache" from 28672 to (2048 * 16) == 32768 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-29 05:47:00.297 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-29 19:01:14.805 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-29 19:11:11.515 120M] Resizing "FTL-dns-cache" from 32768 to (2304 * 16) == 36864 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-29 19:18:08.432 120M] Resizing "FTL-domains" from 61440 to (3072 * 24) == 73728 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-29 19:24:57.372 120M] Resizing "FTL-dns-cache" from 36864 to (2560 * 16) == 40960 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-29 19:47:31.887 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-29 21:00:49.533 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-29 22:20:05.925 120M] Resizing "FTL-dns-cache" from 40960 to (2816 * 16) == 45056 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-30 10:46:45.404 120M] Resizing "FTL-dns-cache" from 45056 to (3072 * 16) == 49152 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-30 12:16:48.720 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 13:18:05.756 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 14:13:31.336 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 17:40:34.944 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 18:11:01.285 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 19:23:49.622 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 20:41:22.299 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 21:00:11.269 120M] Resizing "FTL-domains" from 73728 to (3584 * 24) == 86016 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-30 21:51:11.841 120M] Resizing "FTL-dns-cache" from 49152 to (3328 * 16) == 53248 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-30 21:53:06.695 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 21:54:25.826 120M] Resizing "FTL-strings" from 122880 to (163840 * 1) == 163840 (/dev/shm: 1.8MB used, 67.1MB total, FTL uses 1.8MB)
[2024-03-30 22:14:31.434 120M] Resizing "FTL-dns-cache" from 53248 to (3584 * 16) == 57344 (/dev/shm: 1.9MB used, 67.1MB total, FTL uses 1.9MB)
[2024-03-30 22:47:31.884 120M] Resizing "FTL-dns-cache" from 57344 to (3840 * 16) == 61440 (/dev/shm: 1.9MB used, 67.1MB total, FTL uses 1.9MB)
[2024-03-30 23:31:38.540 120M] Resizing "FTL-dns-cache" from 61440 to (4096 * 16) == 65536 (/dev/shm: 1.9MB used, 67.1MB total, FTL uses 1.9MB)
[2024-03-30 23:34:12.323 120M] ***** Ignored unknown DNSSEC status "TRUNCATED"
[2024-03-30 23:43:48.987 120M] WARNING in dnsmasq core: no address range available for DHCP request via docker0
[2024-03-30 23:44:01.054 120/T145] ERROR: SQL query "END TRANSACTION" failed: database is locked (SQLITE_BUSY)
[2024-03-30 23:44:01.055 120/T145] END TRANSACTION failed when trying to store queries to long-term database
[2024-03-30 23:44:01.055 120/T145] Keeping queries in memory for later new attempt
