Hello all,
Ever since I have discovered Pi-Hole my life changed! It is amazing and I had no problems with it. There is one small quirk which is a bit annoying in the web interface.
As you can see, the tooltip window in always below the pointer and is always partly hidden so that when I move the mouse over a peak I cannot see all the clients IPs. Is there a way to make it unhidden? There are places where almost nothing of that window is visible.
Keep up the good work!
