ad blocking for entire network
Not ad blocking for entire network
*** [ INITIALIZING ]
[i] 2018-05-26:00:04:28 debug log has been initialized.
[i] Core: v3.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3.1-0-gfbee18e
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.27
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✗] No IPv4 address(es) found on the wlan0 interface.
[✗] No IPv6 address(es) found on the wlan0 interface.
* Pinging 192.168.1.1...
[22] is in use by sshd
[53] is in use by dnsmasq
[80] is in use by lighttpd
[] is in use by
[✓] an-retargeting.awsotherlevels.com is 192.168.1.49 via localhost (127.0.0.1)
[✗] Failed to resolve an-retargeting.awsotherlevels.com via Pi-hole (192.168.1.49)
[✓] doubleclick.com is 172.217.11.78 via a remote, public DNS server (8.8.8.8)
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
DNSMASQ_LISTENING=single
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
TEMPERATUREUNIT=F
WEBUIBOXEDLAYOUT=boxed
DHCP_START=192.168.1.201
DHCP_END=192.168.1.251
DHCP_ROUTER=192.168.1.1
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=false
DHCP_ACTIVE=false
PIHOLE_INTERFACE=wlan0
IPV4_ADDRESS=192.168.1.49/24
IPV6_ADDRESS=
PIHOLE_DNS_1=192.168.1.1
PIHOLE_DNS_2=
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
[✓] X-Pi-hole: A black hole for Internet advertisements.
[✓] X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 7185475 May 25 23:52 /etc/pihole/gravity.list
192.168.1.49 0--foodwarez.da.ru
192.168.1.49 0-0-0-0-0-0proxy.tserv.se
192.168.1.49 0-0-0.6te.net
192.168.1.49 0-29.com
192.168.1.49 zzsyw.com
192.168.1.49 zztxdown.com
192.168.1.49 zzz.clickbank.net
192.168.1.49 zzzrtrcm2.com
-rw-r--r-- 1 root root 782 May 11 04:27 /etc/pihole/adlists.list
https://v.firebog.net/hosts/Airelle-hrsk.txt
https://v.firebog.net/hosts/Airelle-trc.txt
https://adaway.org/hosts.txt
https://hosts-file.net/grm.txt
-rw-r--r-- 1 root root 46 May 25 23:52 /etc/pihole/local.list
192.168.1.49 raspberrypi
192.168.1.49 pi.hole
-rw-r--r-- 1 root root 234 May 25 23:51 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1523 May 25 23:51 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=192.168.1.1
domain-needed
bogus-priv
interface=wlan0
-rw-r--r-- 1 root root 3027 May 25 23:51 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1496 May 25 23:51 /etc/cron.d/pihole
10 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
24 19 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 463 May 25 23:44 /var/log/lighttpd/error.log
2018-05-21 06:25:04: (server.c.1534) logfiles cycled UID = 0 PID = 29772
2018-05-25 22:30:16: (log.c.217) server started
2018-05-25 23:02:55: (server.c.1828) server stopped by UID = 0 PID = 1
2018-05-25 23:03:41: (log.c.217) server started
2018-05-25 23:05:59: (log.c.217) server started
2018-05-25 23:52:09: (server.c.1828) server stopped by UID = 0 PID = 1
2018-05-25 23:52:12: (log.c.217) server started
2018-05-25 23:44:05: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 1070 May 26 00:04 /var/log/pihole-FTL.log
[2018-05-26 00:04:25.850] Gravity list entries: 200500
[2018-05-26 00:04:25.850] No blacklist present
[2018-05-26 00:04:25.851] No wildcard blocking list present
[2018-05-26 00:04:25.854] Notice: Increasing queries struct size from 0 to 10000 (440.19 KB)
[2018-05-26 00:04:25.855] Notice: Increasing domains struct size from 0 to 1000 (460.19 KB)
[2018-05-26 00:04:25.855] Notice: Increasing clients struct size from 0 to 10 (460.35 KB)
[2018-05-26 00:04:25.856] New client: 127.0.0.1 localhost (0/10)
[2018-05-26 00:04:25.856] Notice: Increasing forwarded struct size from 0 to 4 (460.45 KB)
[2018-05-26 00:04:25.869] New forward server: 192.168.1.1 (0/4)
[2018-05-26 00:04:25.869] Notice: Increasing overTime struct size from 0 to 100 (464.46 KB)
[2018-05-26 00:04:25.883] New client: 192.168.1.9 (1/10)
[2018-05-26 00:04:25.897] New client: 192.168.1.180 (2/10)
[2018-05-26 00:04:25.910] New client: 192.168.1.137 (3/10)
[2018-05-26 00:04:25.915] Imported 169 queries from the long-term database
[2018-05-26 00:04:25.915] Reading from /var/log/pihole.log (rw-r--r--)
-rw-r--r-- 1 dnsmasq root 5555 May 26 00:04 /var/log/pihole.log
-----head of pihole.log------
May 26 00:04:25 dnsmasq[449]: 314 127.0.0.1/39933 query[PTR] 1.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:25 dnsmasq[449]: 314 127.0.0.1/39933 config 192.168.1.1 is NXDOMAIN
May 26 00:04:25 dnsmasq[449]: 315 127.0.0.1/37732 query[PTR] 9.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:25 dnsmasq[449]: 315 127.0.0.1/37732 config 192.168.1.9 is NXDOMAIN
May 26 00:04:25 dnsmasq[449]: 316 127.0.0.1/34511 query[PTR] 180.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:25 dnsmasq[449]: 316 127.0.0.1/34511 config 192.168.1.180 is NXDOMAIN
May 26 00:04:25 dnsmasq[449]: 317 127.0.0.1/41028 query[PTR] 137.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:25 dnsmasq[449]: 317 127.0.0.1/41028 config 192.168.1.137 is NXDOMAIN
May 26 00:04:25 dnsmasq[449]: 318 127.0.0.1/48980 query[PTR] 9.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:25 dnsmasq[449]: 318 127.0.0.1/48980 config 192.168.1.9 is NXDOMAIN
May 26 00:04:25 dnsmasq[449]: 319 127.0.0.1/45310 query[PTR] 180.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:26 dnsmasq[449]: 319 127.0.0.1/45310 config 192.168.1.180 is NXDOMAIN
May 26 00:04:26 dnsmasq[449]: 320 127.0.0.1/52488 query[PTR] 137.1.168.192.in-addr.arpa from 127.0.0.1
May 26 00:04:26 dnsmasq[449]: 320 127.0.0.1/52488 config 192.168.1.137 is NXDOMAIN
May 26 00:04:28 dnsmasq[449]: 321 127.0.0.1/53234 query[A] api.github.com from 127.0.0.1
May 26 00:04:28 dnsmasq[449]: 321 127.0.0.1/53234 cached api.github.com is 192.30.255.116
May 26 00:04:28 dnsmasq[449]: 321 127.0.0.1/53234 cached api.github.com is 192.30.255.117
May 26 00:04:28 dnsmasq[449]: 322 127.0.0.1/53234 query[AAAA] api.github.com from 127.0.0.1
May 26 00:04:28 dnsmasq[449]: 322 127.0.0.1/53234 cached api.github.com is NODATA-IPv6
May 26 00:04:29 dnsmasq[449]: 323 127.0.0.1/51845 query[A] api.github.com from 127.0.0.1
[✓] ** FINISHED DEBUGGING! **
