Not working / Pi-hole Core v5.18 released to fix
just updated but got error:
where as
Are you able to read that file as the user running Pi-hole?
yes
What does
stat -c "%a" /usr/local/etc/BLOCKLIST
show?
Are you user pi is the user for Pi-hole? Typically it's pihole.
pi@pihole:[/usr/local/etc/BLOCKLIST] $ stat -c "%a" /usr/local/etc/BLOCKLIST
755
running user is pihole - correct, but
sudo to not possible "This account is currently not available."
drwxr-xr-x 3 root root 4096 Aug 19 2022 BLOCKLIST
Thanks, can you do that stat for the file?
stat -c "%a" /usr/local/etc/BLOCKLIST/UNITED_BLOCKING.txt
pi@pihole:[/usr/local/etc/BLOCKLIST] $ stat -c "%a" /usr/local/etc/BLOCKLIST/UNITED_BLOCKING.txt
444
Thanks, checking it now.
Okay, setting up a point release to tweak the comparisons.
thx, testing, will come back
looks good now! Thx for the quick fix - anything left to be done in addition manually (fixing?) on my side?
