When Raspbian starts, Pi-Hole should start along with the FTL engine.
When Raspbian starts, Pi-Hole starts, but not the FTL engine. To get FTL to start, I have to SSH into the device and run sudo service pihole-FTL restart on each boot.
Sorry, I forgot I set it to use ethernet and not wi-fi, though there was network connectivity via wi-fi already. Here's the debug token with the ethernet connected: gxfa9ry0rp
You're IP address is different than what Pi-hole is configured to use. Your device has 192.168.1.88 but it's configured to use 192.168.1.99. Run pihole -r > Reconfigure
