Shairport-sync disappeared
#1
Hello,
I have a CHIP used with shairport-sync. After i installed pihole i can’t find shairport in my devices. Tried to disable pihole and dnsmasq but no luck. Anyone has faced this problem?
**netstat -ap tcp | grep -i "listen"**
tcp        0      0 chip:4711               *:*                     LISTEN      825/pihole-FTL
tcp        0      0 *:5000                  *:*                     LISTEN      402/shairport-sync
tcp        0      0 *:http                  *:*                     LISTEN      342/lighttpd
tcp        0      0 *:domain                *:*                     LISTEN      767/dnsmasq
tcp        0      0 *:ssh                   *:*                     LISTEN      296/sshd
tcp6       0      0 localhost:4711          [::]:*                  LISTEN      825/pihole-FTL
tcp6       0      0 [::]:5000               [::]:*                  LISTEN      402/shairport-sync
tcp6       0      0 [::]:http               [::]:*                  LISTEN      342/lighttpd
tcp6       0      0 [::]:domain             [::]:*                  LISTEN      767/dnsmasq
tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      296/sshd
unix  2      [ ACC ]     STREAM     LISTENING     1791     1/init              /run/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     3591     1/init              /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     9225     825/pihole-FTL      /var/run/pihole/FTL.sock
unix  2      [ ACC ]     STREAM     LISTENING     6666     406/php-cgi         /var/run/lighttpd/php.socket-0
unix  2      [ ACC ]     SEQPACKET  LISTENING     1810     1/init              /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     3604     1/init              /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     1814     1/init              /run/systemd/journal/stdout
unix  2      [ ACC ]     STREAM     LISTENING     5959     208/NetworkManager  /var/run/NetworkManager/private
unix  2      [ ACC ]     STREAM     LISTENING     5965     208/NetworkManager  /var/run/NetworkManager/private-dhcp
unix  2      [ ACC ]     STREAM     LISTENING     5798     531/dhcpcd          /var/run/dhcpcd.sock
unix  2      [ ACC ]     STREAM     LISTENING     9186     816/systemd         /run/user/999/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     8439     691/systemd         /run/user/0/systemd/private
**shairport-sync -vvv**
Looking for the configuration file "/etc/shairport-sync.conf".
Looking for configuration file at full path "/etc/shairport-sync.conf"
Output device name is "default".
The processor is running little-endian.
Version: "2.8.6-OpenSSL-Avahi-ALSA-pulse-dummy-stdout-pipe-soxr-metadata-sysconfdir:/etc"
statistics_requester status is 0.
daemon status is 0.
rtsp listening port is 5000.
udp base port is 6001.
udp port range is 100.
Shairport Sync player name is "Chip".
Audio Output name is "(null)".
on-start action is "(null)".
on-stop action is "(null)".
wait-cmd status is 0.
mdns backend "(null)".
userSuppliedLatency is 0.
AirPlayLatency is -1.
iTunesLatency is -1.
forkedDaapdLatency is -1.
stuffing option is "0" (0-basic, 1-soxr).
resync time is 2205.
allow a session to be interrupted: 0.
busy timeout time is 120.
drift tolerance is 88 frames.
password is "(null)".
ignore_volume_control is 0.
playback_mode is 0 (0-stereo, 1-mono).
disable_synchronization is 0.
use_mmap_if_available is 1.
audio backend desired buffer length is 6615.
audio backend latency offset is 0.
volume range in dB (zero means use the range specified by the mixer): 0.
zeroconf regtype is "_raop._tcp".
configuration file name "/etc/shairport-sync.conf" resolves to "/etc/shairport-sync.conf".
metdata enabled is 0.
metadata pipename is "(null)".
metadata socket address is "(null)" port 0.
metadata socket packet size is "500".
get-coverart is 0.
Successful Startup
avahi: avahi_register.
avahi: register_service.
avahi: service 'E61E34B450F3@Chip' group is not yet committed.
avahi: request to add "_raop._tcp" service without metadata
avahi: service 'E61E34B450F3@Chip' group is registering.
avahi: service 'E61E34B450F3@Chip' successfully added.
**avahi-browse -ar**
+  wlan0 IPv4 20D1A8E3F028@Chip.local                       AirTunes Remote Audio local
+  wlan0 IPv4 chip [cc:79:cf:22:1f:4f]                      Workstation          local
=  wlan0 IPv4 20D1A8E3F028@Chip.local                       AirTunes Remote Audio local
   hostname = [chip.local]
   address = [192.168.168.20]
   port = [5000]
   txt = ["pw=false" "txtvers=1" "ch=2" "cn=0,1" "ek=1" "et=0,1" "sv=false" "da=true" "sr=44100" "ss=16" "vn=65537" "tp=TCP,UDP" "vs=105.1" "am=ShairportSync" "fv=76400.10" "sf=0x4"]
=  wlan0 IPv4 chip [cc:79:cf:22:1f:4f]                      Workstation          local
   port = [9]
   txt = []
