This has been asked about (and covered) a few times so I thought I'd add a $0.02 solution.
This assumes you're running Android. Install Raspberry SSH Lite from the Android market and add/create these two scripts to any directory of choice on your RPi (don't forget to chmod +x
). I put them in /root
In Raspberry SSH Lite add a button with the command sh /root/en-pihole.sh
plus your SSH credentials. Save, then clone that button but point it to sh /root/dis-pihole.sh
. That's it. Pressing Disable will rename your pihole.conf
file to .bak
, effectively disabling ad-blocking. Enabling will reverse this.
Some caveats: I'm running these under root. Using sudo
with a less privileged account is always a better choice. Also, this could be done with a single script but I'm lazy.
