Hello Folks,
OK, this is a goofy one, and I am really stuck. Hang on for the ride being that I have listed the back story, some steps taken, and the issues is reproducible.
I had recently built a new PC, MoBo, CPU, the works and replaced it with the same old HDD where everything was working as expected before with the previous PC. Obviously i needed to update things for the new video card and Network devices.
Upon testing, after a reboot, I was not able to access the Internet, and noticed that I would loose my gateway, and I found that if I open Debian 9 network manager gui, bounce the wired interface, I would then get the GW and could then access the Internet. Trust me, I will get to the PIHole and PiVPN here soon
I discovered that if I also had wired as well as WiFi, I would get the GW for both the wired and WiFi, but if I connect to the PiVPN I would not be able to connect to the VPN, but if I open the network manager and off / on the wired interface, I would then be able to connect to the VPN, and it would work as expected.
Here are the route -n and ifconfig before and after:
Before
route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.50.1 0.0.0.0 UG 202 0 0 enp37s0
0.0.0.0 192.168.50.1 0.0.0.0 UG 303 0 0 wlp36s0
10.8.0.0 0.0.0.0 255.255.255.0 U 0 0 0 tun0
192.168.50.0 0.0.0.0 255.255.255.0 U 202 0 0 enp37s0
192.168.50.0 0.0.0.0 255.255.255.0 U 303 0 0 wlp36s0
ifconfig
enp37s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.50.70 netmask 255.255.255.0 broadcast 192.168.50.255
inet6 fe80::7285:c2ff:fe5e:1e20 prefixlen 64 scopeid 0x20<link>
ether 70:85:c2:5e:1e:20 txqueuelen 1000 (Ethernet)
RX packets 427791 bytes 558676075 (532.7 MiB)
RX errors 0 dropped 2 overruns 0 frame 0
TX packets 328483 bytes 25907559 (24.7 MiB)
device memory 0xf7500000-f751ffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 76257 bytes 914413164 (872.0 MiB)
TX packets 76257 bytes 914413164 (872.0 MiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.8.0.1 netmask 255.255.255.0 destination 10.8.0.1
inet6 fe80::eca2:3d08:4e55:5a0e prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
TX packets 595 bytes 33940 (33.1 KiB)
wlp36s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.50.139 netmask 255.255.255.0 broadcast 192.168.50.255
inet6 fe80::99e1:c5d0:715f:6303 prefixlen 64 scopeid 0x20<link>
ether 28:c6:3f:16:3b:13 txqueuelen 1000 (Ethernet)
RX packets 19884 bytes 4803946 (4.5 MiB)
TX packets 1218 bytes 250339 (244.4 KiB)
AFTER Wired interface bounce
# route -n
0.0.0.0 192.168.50.1 0.0.0.0 UG 100 0 0 enp37s0
192.168.50.0 0.0.0.0 255.255.255.0 U 100 0 0 enp37s0
root@Familyroom:/home/jc# ifconfig
RX packets 429247 bytes 560396391 (534.4 MiB)
TX packets 329658 bytes 26035465 (24.8 MiB)
RX packets 77427 bytes 931854863 (888.6 MiB)
TX packets 77427 bytes 931854863 (888.6 MiB)
TX packets 603 bytes 35236 (34.4 KiB)
RX packets 20055 bytes 4848635 (4.6 MiB)
TX packets 1317 bytes 278803 (272.2 KiB)
Maybe I have been working on this too long, but the only difference that I see is the metric change after the interface bounce.
I do have the Pihole as the DHCP server so I wondered if this was part of the issue, it was not before the build, however I did move DHCP back to the router, and there was no change....
Your debug token is: osh1zzjrc8
