@diginc - I'm not sure if this is an issue with the docker container, pi hole, or me. It is probably the last option, but I'm pinging you just in case it is the first on.
I start up the Pi Hole docker container using the provided script (link below) and pi hole starts running properly
I start up the Pi Hole docker container using the provided script. Container launches and attaches to the requisite ports. It even works as a name server, but isn't blocking anything.
I point my browser at http://serverip/ and I get an error that says [ERROR] File not found: /etc/pihole/setupVars.conf
If I go to http://serverip/admin I do get a page. But when I try to do an Update Lists, I get an error that says...
Installation Failure: /etc/pihole/setupVars.conf does not exist!
Please run 'pihole -r', and choose the 'reconfigure' option to fix.
I launched a bash session with the running container (docker exec -it pihole /bin/bash) and tried running pihole -r
I accepted all of the defaults - output below.
[✓] Disk space check
[✗] Checking apt-get for upgraded packages
Kernel update detected. If the install fails, please reboot and try again
[i] Checking for apt-utils (will be installed)
[i] Checking for dialog (will be installed)
[i] Checking for debconf (will be installed)
[i] Checking for dhcpcd5 (will be installed)
[i] Checking for git (will be installed)
[i] Checking for iproute2 (will be installed)
[i] Checking for whiptail (will be installed)
[✓] Stopping dnsmasq service...
[✓] Stopping lighttpd service...
RTNETLINK answers: Operation not permitted
Then the web server and name server stop working all together.
Further investigation:
I suspect the part of the startup script that parses out IP and IPV6 isn't working correctly.
Output of ip route get 8.8.8.8 is:
8.8.8.8 via 192.168.1.1 dev enp0s25 src 192.168.1.75 uid 1000
cache
Output of ip -6 route get 2001:4860:4860::8888 is:
2001:4860:4860::8888 from :: via fe80::1ad6:c7ff:fe24:5897 dev enp0s25 proto ra src 2605:a000:1230:e145:85fd:604a:b2:848 metric 100 pref medium
Output of echo "IP: ${IP} - IPv6: ${IPv6}" when the start up script is run is:
IP: 1000 - IPv6: src
Further further investigation:
Once I got IPv6 set up for docker, I was able to hard code in IPv4 and IPv6 addresses in the startup script. So, this lends credence to the logic in the startup script not parsing out addresses correctly.
ujvk4j9e2y
