LAN devices should use the device for filtering
Installed fine, system is active, no queries
cyesffpey4
cyesffpey4
Have you specified the device of the Pi as your DNS on your clients?
There's no way for them to pick it up unless specified ...
Yes, I have set the primary dns in my router to the static ip of my pi, with a secondary to 1.1.1.1 as a backup.
When using a secondary DNS queries will slip though it (the secondary DNS does NOT kick in ONLY when DNS1 has an outage).
Run a nslookup flurry.com
on a client and the same command on the pi-hole device.
What is the output ?
I didnt realize that. let me issue that lookup
This looks good. You should see a blocked entry in your query log now.
What about the same command executed on a client device (computer).
same thing on a client device, and unfortunately nothing on the blocked. i did also remove secondary dns entry too.
Based on the above nslookup, the query was intercepted and router to the raspberry pi.
Your web interface shows no queries ?
Try clearing cache and cookies.
It should show.
What's the output of pihole -v
and dnsmasq -v
pihole -v
Pi-hole version is v3.2.1 (Latest: v3.3.1)
AdminLTE version is v3.2.1 (Latest: v3.3)
FTL version is v3.0 (Latest: v3.0)
Dnsmasq version 2.72 Copyright (c) 2000-2014 Simon Kelley
Compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect
This software comes with ABSOLUTELY NO WARRANTY.
Dnsmasq is free software, and you are welcome to redistribute it
under the terms of the GNU General Public License, version 2 or 3.
what about curl http://192.168.7.15/admin/api.php
{"domains_being_blocked":122096,"dns_queries_today":0,"ads_blocked_today":0,"ads_percentage_today":0,"unique_domains":0,"queries_forwarded":0,"queries_cached":0,"clients_ever_seen":0,"unique_clients":0,"status":"enabled"}
what happens when you try to open flurry.com on the device? Do you get a Pi-hole splash page like this:
Interesting, i receive a blocked message just as you show, however the dashboard still shows 0.
Tried this via gui on the pi, and a windows client with the same result.
Ok. I think this will fix your issue:
Try it in one line:
sudo service pihole-FTL stop && sudo mv /etc/pihole/pihole-FTL.db /etc/pihole/pihole-FTL.db.old && sudo service pihole-FTL start
Back online, but still 0's in the dashboard.
I thought we had it that time =)
