I am looking for guide - how to import RegEx to Pi-hole?
I have found code (([A-Za-z0-9.-/]+)?)pageid=[0-9]{1,30}
on web page:
Thanks for reply`s
on web page:
Thanks for reply`s
The RegEx you quoted will not work on the DNS level as it is a filter meant for blocking on a URL level. Due to fundamental technical limitations, this is (and will likely never be) possible with Pi-hole.
See
Thank`s ... so youtube is the winner - but hope not for long time slight
