Execute tail -f /var/log/pihole-FTL.log
In a second SSH connection execute
sudo service pihole-FTL stop
followed by
sudo service pihole-FTL start
Any clues, warnings or errors in the tail
-output?
followed by
-output?
Not sure if this matters, but I'm doing this through VNC/the RBP Desktop.
I get the following result. I don't see anything weird other than "found no readable FTL config file"
[2018-05-19 10:43:07.785] ########## FTL started! ##########
[2018-05-19 10:43:07.790] FTL branch: FTLDNS
[2018-05-19 10:43:07.790] FTL version:
[2018-05-19 10:43:07.795] FTL commit: fa0045e
[2018-05-19 10:43:07.796] FTL date: 2018-05-12 15:43:49 -0400
[2018-05-19 10:43:07.797] FTL user: pihole
[2018-05-19 10:43:07.797] Notice: Found no readable FTL config file
[2018-05-19 10:43:07.798] Using default settings
[2018-05-19 10:43:07.798] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-05-19 10:43:07.799] SOCKET_LISTENING: only local
[2018-05-19 10:43:07.799] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-05-19 10:43:07.800] MAXDBDAYS: max age for stored queries is 365 days
[2018-05-19 10:43:07.801] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-05-19 10:43:07.803] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-05-19 10:43:07.804] DBINTERVAL: saving to DB file every minute
[2018-05-19 10:43:07.804] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-05-19 10:43:07.805] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-05-19 10:43:07.810] PRIVACYLEVEL: Set to 0
[2018-05-19 10:43:07.811] IGNORE_LOCALHOST: Show queries from localhost
[2018-05-19 10:43:07.812] BLOCKINGMODE: Pi-hole's IP for blocked domains
[2018-05-19 10:43:07.813] BLOCKINGREGEX: Not set
[2018-05-19 10:43:07.814] Finished config file parsing
[2018-05-19 10:43:07.871] Database successfully initialized
[2018-05-19 10:43:07.875] Imported 0 queries from the long-term database
[2018-05-19 10:43:07.886] -> Total DNS queries: 0
[2018-05-19 10:43:07.887] -> Cached DNS queries: 0
[2018-05-19 10:43:07.887] -> Forwarded DNS queries: 0
[2018-05-19 10:43:07.888] -> Exactly blocked DNS queries: 0
[2018-05-19 10:43:07.888] -> Wildcard blocked DNS queries: 0
[2018-05-19 10:43:07.889] -> Unknown DNS queries: 0
[2018-05-19 10:43:07.896] -> Unique domains: 0
[2018-05-19 10:43:07.901] -> Unique clients: 0
[2018-05-19 10:43:07.902] -> Known forward destinations: 0
[2018-05-19 10:43:07.903] Successfully accessed setupVars.conf
If your FTL is down I would expect an entry in the log file.
This is ok, the file /etc/pihole/pihole-FTL.conf
is optional.
I don't know much about the command journalctl
, but is there anything interesting in the output of
journalctl -u pihole-FTL.service -b --no-pager
That says:
Hint: You are currently not seeing messages from other users and the system.
Users in the 'systemd-journal' group can see all messages. Pass -q to
turn off this notice.
No journal files were opened due to insufficient permissions.
sudo journalctl -u pihole-FTL.service -b --no-pager
Apologies, I actually saw that it needed sudo and thought I re-ran the command with it. I've been distracted trying to help a friend build his first PC over the phone, which is less than pleasant.
You have my full attention now.
-- Logs begin at Thu 2018-05-17 20:52:44 PDT, end at Sat 2018-05-19 12:24:29 PDT. --
May 17 20:53:14 Corpus_Colossus systemd[1]: Starting LSB: pihole-FTL daemon...
May 17 20:53:16 Corpus_Colossus pihole-FTL[293]: Not running
May 17 20:53:17 Corpus_Colossus pihole-FTL[293]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
May 17 20:53:32 Corpus_Colossus su[676]: Successful su for pihole by root
May 17 20:53:32 Corpus_Colossus su[676]: + ??? root:pihole
May 17 20:53:32 Corpus_Colossus su[676]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 17 20:53:38 Corpus_Colossus pihole-FTL[293]: dnsmasq: illegal repeated keyword at line 35 of /etc/dnsmasq.d/[default-config]01-pihole.conf.dpkg-old
May 17 20:53:39 Corpus_Colossus systemd[1]: Started LSB: pihole-FTL daemon.
May 19 10:42:34 Corpus_Colossus systemd[1]: Stopping LSB: pihole-FTL daemon...
May 19 10:42:34 Corpus_Colossus pihole-FTL[11714]: Not running
May 19 10:42:34 Corpus_Colossus systemd[1]: Stopped LSB: pihole-FTL daemon.
May 19 10:43:06 Corpus_Colossus systemd[1]: Starting LSB: pihole-FTL daemon...
May 19 10:43:06 Corpus_Colossus pihole-FTL[11752]: Not running
May 19 10:43:06 Corpus_Colossus pihole-FTL[11752]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
May 19 10:43:06 Corpus_Colossus su[11775]: Successful su for pihole by root
May 19 10:43:06 Corpus_Colossus su[11775]: + ??? root:pihole
May 19 10:43:06 Corpus_Colossus su[11775]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 19 10:43:07 Corpus_Colossus pihole-FTL[11752]: dnsmasq: illegal repeated keyword at line 35 of /etc/dnsmasq.d/[default-config]01-pihole.conf.dpkg-old
May 19 10:43:08 Corpus_Colossus systemd[1]: Started LSB: pihole-FTL daemon.
Looks like maybe that is the problem? The readme file in there straight up says it won't read things ending in dpkg-old. Is there a way to rename this file so I can keep a copy AND not have it read by the system?
Never read about a file named /etc/dnsmasq.d/[default-config]01-pihole.conf.dpkg-old
Nevertheless, what is line 35 in /etc/dnsmasq.d/01-pihole.conf
Did you already try pihole -r
> Repair?
That is what I named the file to keep as a back-up copy of the original file. There is a readme file in this directory that says
"All files in this directory will be read by dnsmasq as
configuration files, except if their names end in
".dpkg-dist",".dpkg-old" or ".dpkg-new"
This can be changed by editing /etc/default/dnsmasq"
So, I added .dpkg-old to the end of the file copy I made ([default-config]01-pihole.conf) so that it would not be read, but it looks like it is being read anyway? I also have a similar file in here for dnscrypt called "[default-config]02-dnscrypt.conf.dpkg-old".
Please let me know if you think these are causing issues and should be removed or somehow renamed to be ignored.
In any case, line 35 appears to be:
"cache-size=10000"
I have tried pihole -r and same result.
There is a similar posting
Ok, say I deleted [default-config]01-pihole.conf.dpkg-old because it was clearly causing problems.
I re-ran pihole -r and am getting the same result, so I re-ran sudo journalctl -u pihole-FTL.service -b --no-pager and now get:
-- Logs begin at Sat 2018-05-19 12:53:50 PDT, end at Sat 2018-05-19 12:55:50 PDT. --
May 19 12:54:02 Corpus_Colossus systemd[1]: Starting LSB: pihole-FTL daemon...
May 19 12:54:04 Corpus_Colossus pihole-FTL[271]: Not running
May 19 12:54:05 Corpus_Colossus pihole-FTL[271]: chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
May 19 12:54:21 Corpus_Colossus su[674]: Successful su for pihole by root
May 19 12:54:21 Corpus_Colossus su[674]: + ??? root:pihole
May 19 12:54:21 Corpus_Colossus su[674]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 19 12:54:23 Corpus_Colossus pihole-FTL[271]: dnsmasq: failed to create listening socket for port 53: Address already in use
May 19 12:54:23 Corpus_Colossus systemd[1]: Started LSB: pihole-FTL daemon.
I'm assuming "May 19 12:54:23 Corpus_Colossus pihole-FTL[271]: dnsmasq: failed to create listening socket for port 53: Address already in use" is the issue, so read the link you sent and found /etc/dnsmasq.conf, but I'm not sure what to do with this file. It is huge and has tons of options.
One line that I see that may be relevant is:
"Listen on this specific port instead of the standard DNS port
(53). Setting this to zero completely disables DNS function,
leaving only DHCP and/or TFTP.
port=5353"
That's all currently commented out, should I uncomment and change it to port=5354?
As there is already a program running on port 53, find out which one
sudo netstat -tulpen | grep ":53\s"
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 0 13360 285/dnscrypt-proxy
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 9702 245/avahi-daemon: r
udp 0 0 127.0.0.1:53 0.0.0.0:* 0 13359 285/dnscrypt-proxy
udp6 0 0 :::5353 :::* 108 9703 245/avahi-daemon: r
Edit: Isn't this the exact same problem I had before? I'm also not clear on why dnscrypt-proxy is running on port 5353 still. Should I uncomment the "listen_addresses = ['127.0.0.1:5354', '[::1]:5354']" line in dnscrypt-proxy.toml?
Remove a # at the beginning of line listen_addresses =
Then you have to restart dnscrypt-proxy with (adapt the path if needed)
sudo /opt/dnscrypt-proxy/dnscrypt-proxy -service restart
Check again with sudo netstat -tulpen | grep ":53\s"
Running sudo netstat -tulpen | grep 53 after restarting dnscrypt-proxy gives:
tcp 0 0 127.0.0.1:5354 0.0.0.0:* LISTEN 0 26388 1903/dnscrypt-proxy
tcp6 0 0 ::1:5354 :::* LISTEN 0 26391 1903/dnscrypt-proxy
udp 0 0 127.0.0.1:5354 0.0.0.0:* 0 26387 1903/dnscrypt-proxy
udp6 0 0 ::1:5354 :::* 0 26389 1903/dnscrypt-proxy
Edit: Now pihole says DNS service not running and I can no longer access any websites/ping/resolve on the RBP.
The file /etc/pihole/setupVars.conf
should contain the lines
PIHOLE_DNS_1=127.0.0.1#5354
PIHOLE_DNS_2=
and no further PIHOLE_DNS lines.
should contain server=127.0.0.1#5354
Now sudo service pihole-FTL restart
That worked! Thank you so much for your help!
